Re-Order CATIA Tree 16
weagan22
Aerospace
Aug 27, 2015
81
All,
I am working on a macro to re-order the product tree. I first developed a macro that cuts and pastes the each of the components in the right order. This worked great but has the issue of breaking any drawings that are linked to the components. As far as I know the only way to re-order the tree without breaking links is using the "Graph tree Reorder" command. I have had some success pushing keystrokes (sendkeys) into this command to perform the required re-ordering but I am running into an issue as the model gets larger allowing time for the command to open prior to sending keys is proving difficult. I have tried using "Sub Sleep Lib "kernel32"", Application.Wait (Now + TimeValue("00:00:10")), sending the program into a loop for a set period of time, and CATIA.RefreshDisplay = True. All of these pause the macro, but the command doesn't open while the code is paused. Any ideas?
Public Declare PtrSafe Sub mouse_event Lib "user32" (ByVal dwFlags As Long, ByVal dx As Long, ByVal dy As Long, ByVal cButtons As Long, ByVal dwExtraInfo As Long)
Public Const MOUSEEVENTF_LEFTDOWN = &H2
Public Const MOUSEEVENTF_LEFTUP = &H4
Public Const MOUSEEVENTF_RIGHTDOWN As Long = &H8
Public Const MOUSEEVENTF_RIGHTUP As Long = &H10
'Declare sleep
Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Sub CATOrder()
Dim selectProducts As Products
Dim Item As Product
Dim i, d, m, k, g As String
Dim prodCnt, pn, currentPos, position, cntr, bs As Integer
Dim continue As Boolean
Dim pastPos() As Integer
Dim timer As Double
On Error GoTo 2
Set selectProducts = CATIA.ActiveDocument.Selection.Item2(1).Value.Products
'Open Excel
Dim Excel As Object
Set Excel = CreateObject("Excel.Application")
Excel.Visible = True
Excel.workbooks.Add
Excel.Cells(1, 1) = "Part Number"
Excel.Cells(1, 2) = "Detail Number"
Excel.Cells(1, 3) = "Instance Name"
Excel.Cells(1, 4) = "ORDER"
Excel.Cells(1, 1).Font.Bold = True
Excel.Cells(1, 2).Font.Bold = True
Excel.Cells(1, 3).Font.Bold = True
Excel.Cells(1, 4).Font.Bold = True
Excel.Cells(1, 4).Interior.ColorIndex = 15
Excel.Cells(1, 1).Borders.LineStyle = xlContinuous
Excel.Cells(1, 2).Borders.LineStyle = xlContinuous
Excel.Cells(1, 3).Borders.LineStyle = xlContinuous
prodCnt = selectProducts.Count
On Error Resume Next
'Input values into excel
i = 1
g = 2
Do While i < prodCnt + 1
Set Item = selectProducts.Item(i)
pn = InStr(Item.PartNumber, "_")
pn = Right(Item.PartNumber, Len(Item.PartNumber) - pn)
pn = Left(pn, Len(pn) - 2)
Excel.Cells(g, 1) = Item.PartNumber
Excel.Cells(g, 2) = pn
Excel.Cells(g, 3) = Item.Name
Excel.Cells(g, 4) = i
Excel.Cells(g, 1).Borders.LineStyle = xlContinuous
Excel.Cells(g, 2).Borders.LineStyle = xlContinuous
Excel.Cells(g, 3).Borders.LineStyle = xlContinuous
Excel.Cells(g, 4).Borders.LineStyle = xlContinuous
Excel.Cells(g, 4).Interior.ColorIndex = 15
g = g + 1
i = i + 1
Loop
'Sort values in Excel
continue = MsgBox("Sort Excel then press 'OK'.", vbOKCancel)
If continue = vbCancel Then
End
End If
CATIA.StartCommand "Graph tree Reordering"
Sleep 1000
'Application.Wait (Now + TimeValue("00:00:10"))
'timer = Now + 0.0000115
'Do While Now < timer
'bs = bs + 1
'Loop
mouse_event MOUSEEVENTF_LEFTDOWN, 0, 0, 0, 0
Sleep 50
mouse_event MOUSEEVENTF_LEFTUP, 0, 0, 0, 0
Application.SendKeys "{TAB}", True
Excel.Cells(1, 5) = "i"
Excel.Cells(1, 6) = "position"
Excel.Cells(1, 7) = "d"
Excel.Cells(1, 8) = "m"
Excel.Cells(1, 9) = "cntr"
'Sort tree with Graph tree Reordering
i = 1
Excel.Cells(i + 1, 5) = i
position = Excel.Cells(i + 1, 4)
k = i - 2
cntr = 0
Do While k >= 0
If pastPos(k) > position Then
cntr = cntr + 1
End If
k = k - 1
Loop
ReDim Preserve pastPos(i - 1)
pastPos(i - 1) = position
d = position + cntr - i + 1
If i = 1 Then
d = d - 1
End If
m = position + cntr - i
Excel.Cells(i + 1, 9) = cntr
Excel.Cells(i + 1, 6) = position
Excel.Cells(i + 1, 7) = d
Do While d > 0
Call arrowDwn
d = d - 1
Loop
Call tabUp
Excel.Cells(i + 1, 8) = m
Do While m > 0
Call moveUp
m = m - 1
Loop
Call tabDwn
i = i + 1
Sleep 200
Loop
closeExcel = MsgBox("Would you like to close Excel?", vbYesNo)
If closeExcel = vbYes Then
Close Excel
Excel.ActiveWorkbook.Close SaveChanges:=False
Excel.Quit
End If
GoTo 1
2:
MsgBox "Select a product before running macro."
Excel.Quit
1:
End Sub
Function moveUp()
Application.SendKeys "~"
End Function
Function arrowDwn()
Application.SendKeys "{DOWN}"
End Function
Function tabUp()
End Function
Function tabDwn()
Application.SendKeys "+{TAB}"
End Function
Wow. Such a convoluted solution to something Dassault should provide out of the box. I've always found the graph tree reordering function to be lacking in CATIA. But I'm not sure I would trust send keys for this.
Drew Mumaw
Yes, this is a very convoluted solution, but there isn't any other way. I have gotten it to work great on a small product but it fails on a larger product due to the delay from the command opening. Probably due to the time required to gather all of the instance names.
Can't use V6 so that doesn't really help. It's nice that they added this functionality though.
You can also try SmartSort application:
It is doing exactly what you are after but much faster and more reliable way through Windows Automation.
Main Features:
[ul]
[li]Works in Visualization mode or Design mode[/li]
[li]Perfect for large assemblies (no need to switch to Design mode)[/li]
[li]Constraint links are preserved[/li]
[li]No CUT & PASTE operations and no broken links[/li]
[li]No components renaming[/li]
[li]It uses CATIA native Graph tree reordering feature[/li]
[/ul]
Tesak
- Text along a curve for Catia V5
Here is an idea if you hit that wall :)
Of course, the solution is not the "cut&paste" one.
cilici
Yes, it will soon be available. It is in testing now.
cilici
I tried SmartSort. It's really a useful tool for Catia sort, Thanks for Tesak's sharing. I recommand this tool to everybody.
I want to add the "SmartSort" to my Catia toolbar,and created a macro(see bellow),but failed to run.how to fix it?
Any help will be appriciated.
Sub CATMain()
CATIA.SystemService.ExecuteProcessus("D:\00_CATia_tool\SmartSort.exe") 'file position
End Sub
 http://files.engineering.com/getfile.aspx?folder=8b97b76a-adfb-4426-8a08-6d5d00b90a7f&file=error.JPG
Hey llbby, the only way that we found to run SmartSort from CATIA is to run it with a batch file. Basically you have to input a path to a folder and the code writes a batch file then runs it. Here is a snip of the code that we use to do this:
Sub CATMain()
If CATIA.GetWorkbenchId = "Drw" And CATIA.GetWorkbenchId = "DrwBG" Then
MsgBox "Not for drawings.", , "Error"
End
End If
If Len(Dir("C:\Temp\")) = 0 Then
MkDir ("C:\Temp")
End If
runPath = Dir("C:\Temp\SmartSortLoc.txt")
If runPath <> "" Then
Open "C:\Temp\SmartSortLoc.txt" For Input As #1
Line Input #1, runPath
Close #1
End If
Check:
If Dir(runPath & "\") = "" Or runPath = "" Then
runPath = ""
runPath = InputBox("Please input the path to your SmartSort folder e.g. [C:\Users\user.name\Desktop\SmartSort]", "Path")
If runPath = "" Then End
Open "C:\Temp\SmartSortLoc.txt" For Output As #1
Print #1, runPath
Close #1
GoTo Check
End If
Dim apps() As Variant
apps() = AllRunningApps
g = 0
For i = 1 To UBound(apps, 2)
If apps(0, i) = "CNEXT.exe" Then
If g = 0 Then
g = 1
Else
MsgBox "More than one instance of CATIA is running. Please close the other instance of CATIA and try again.", , "Error"
End
End If
End If
Next
If CATIA.GetWorkbenchId <> "Assembly" Then
CATIA.StartWorkbench ("Assembly")
End If
Open runPath & "\AutoPlay.bat" For Output As #1
Print #1, "start /d " & Chr(34) & runPath & Chr(34) & " SmartSort.exe"
Close #1
If Dir(runPath & "\SmartSort.exe") <> "SmartSort.exe" Then
MsgBox "SmartSort.exe was not found. Please make sure that the application is named correctly.", , "Error"
End
End If
Call Shell(runPath & "\AutoPlay.bat", 1)
End Sub
Public Function AllRunningApps() As Variant
Dim strComputer As String
Dim objServices As Object, objProcessSet As Object, Process As Object
Dim oDic As Object, a() As Variant
Set oDic = CreateObject("Scripting.Dictionary")
strComputer = "."
Set objServices = GetObject("winmgmts:\\" & strComputer & "\root\CIMV2")
Set objProcessSet = objServices.ExecQuery("SELECT Name, ProcessID FROM Win32_Process", , 48)
ReDim a(1, 0)
a(0, 0) = ""
For Each Process In objProcessSet
If a(0, 0) = "" Then
a(0, 0) = Process.Properties_("Name").Value
a(1, 0) = Process.Properties_("ProcessID").Value
Else
ReDim Preserve a(1, UBound(a, 2) + 1)
a(0, UBound(a, 2)) = Process.Properties_("Name").Value
a(1, UBound(a, 2)) = Process.Properties_("ProcessID").Value
End If
Next
AllRunningApps = a()
End Function
hi cilici,
it is a great tool. well done.
uhm do you have that kind of tool of renaming every part number or instance name? or just deleting part number or instance name?
thanks
Hi everyone,
Here is my sorter that I created. It can sort based on Boeing detail number (which is what we do here mostly) or by instance name. I have also included the source file so you can add your own sorting algorithm (you just need to sort the values in the right box).
 http://files.engineering.com/getfile.aspx?folder=fea1edd8-247e-4277-a493-2fea70790792&file=Sorter.zip
good job! thanks for sharing
Eric N.
Here is an updated version of Reorder.
It now manages the situations when instances' names are identical except the case (e.g. Part1(Part1.1) versus Part1(PART1.1)).
Please note that the tool is free of use commercially or not.
Any feedback (especially the negative ones) will be appreciated (you can find my email in the file properties).
Calin
Hi ! everyone , Cilici thanks you for sharing it with us.
I-m having a problem using the last reorder version.
I place all parts on the order I want, it starts to run but at the en the next message apears
Could you know what is this happening _
