M
mattcoyle
Guest
Is there any way to reapply changes you made to a drawing template after you have made a drawing with the old template. Our company has about 700 drawings to create, however we noticed that once we create a drawing and finish it, there is no easy way to update the title block other then going into each individual configuration of each drawing and changing them (which can also lead to inconsistent drawings). I have searched the forums and no one seems to have ever had this issue. We are hesitant to start the project until we know absolutely that the title-block and drawing configurations are perfect. Knowing that it wont be easy to change all of the title blocks later on. In pro engineer it lets you change from TB to TB very easily. But with solidworks, using the drawing template seems to be a one time deal.
