we have two trafo for 2 arc furnaces rating 8.5MVA , 11KV /240V with on load tapchanger on HV side max 14 taps.Make AEG germany . Trafo vector group Yd11 , %z = 10
Siemens persons performed ratio and vetor group test with eqiupment :Tettax AG Model # 2791HR
1- They read out the reading from this equipment and divide it by factor 1.5 to get the actual ratio. As i red from my college for vector group YD11 we have
ratio for yd11= (Primary voltage / root 3) / secondary volatge , so the reading is divide by root 3 to get the actual ratio similarly for DY11 multiplied by root 3 to get the actual ratio. But this calcultaion confusing my concept i.e factor 1.5 what does it means .Is it root 3 * cos 30 = 1.5 for phase angle differnce or what ?
2- As far as vector group is concern they calculate it manually ?
i.e connect the U and u phase and applied voltage b/w UV, VW, WU and measure the following reading
W-v = W-w
V-v<U-V
V-v<U-w
I have no idea how these reslut are taken for knowing the vector group what about Dy11 is the same results?
W-v = W-w
V-v<U-V
V-v<U-w
