Hi all, I'm looking for a bit of advice.
When conducting a valve leak test, we pressure the pipework upstream of the valve, record the temperature and pressures (upstream and downstream), leave for 30 minuntes, and then record temperatures and pressures again. We then use ideal gas law (PV=ZnRT) and density at standard conditions to calculate the leak rate through the valve in kg/min. We then determine pass or fail against the performance standard.
However, we have been asked by a 3rd party consultancy to change the way we report this in terms of rate of pressure drop instead of mass (or volumetric) flowrate.
This doesn't seem right to me as a leak rate should be reported in standard conditions to allow us to compare 'apples with apples', as well as having different fixed volumes for different valves across the plant which would skew rate of pressure drop. Am i missing something?
I hope this makes sense!
