Rat Walls
hs0214
Industrial
I'm in the process of preparing to test for a building inspector and the one subject I cannot get a clear cut technical description of is... a Rat Wall. Can anyone direct me to references for a rat wall?
A rat wall is a solid non structural wall that extends far enough into the ground to prevent rats from burrowing underneath. They were required to be 600mm below ground level where I live but are no longer required.
Often the edge footing beam was made deep enough to meet the rat wall requirements.
