Rapid Corrosion of Steel threatens Duluth port
kenvlach
Materials
Apr 12, 2000
2,514
Chicago Tribune, Nov. 25, 2005
By John McCormick, Tribune staff reporter
[free registration required]
"DULUTH, Minn. -- A mystery lurking below the harbor surface here has engineers and scientists debating how to slow the abnormally rapid corrosion that now threatens the long-term structural integrity of the largest port on the Great Lakes.
The corrosion--at a rate believed to be 2 to 10 times faster than expected--is taking place on an estimated 13 miles of steel plates that line the harbor, metal that provides support for bridges, iron ore loading docks and other vital structures.
Theories abound about the cause, ranging from stray electrical currents to road salt runoff to zebra mussels. Lower levels of harbor pollution may also be speeding the corrosion process because there is more dissolved oxygen in the water.
"They are suffering some severe corrosion," said Rudolph Buchheit, a material science and engineering professor at Ohio State University who is studying the problem. "But it is not at all agreed upon why this is happening."
While salt water is known to attack untreated steel, experts say the rate of rust in the fresh water of Duluth-Superior Harbor is unlike anything they have seen on the Great Lakes.
Buchheit said some steel plates that are a half-inch thick or more have been perforated in less than 10 years. "To make it through that thick a material in just a few years is a significant corrosion rate," he said.
After assembling a panel of experts, the U.S. Army Corps of Engineers issued a report this year that said the problem could cost more than $100 million to correct if major replacement of the steel pilings is required.
Some possible causes were ruled out, while additional study was suggested for others. Top theories identified by that report include environmentally influenced changes in water chemistry, microbe activity, dissolved chlorides from deicing salts and rising levels of dissolved oxygen.
Also under consideration are zebra mussels, which could protect some steel while concentrating corrosion at other water depths. Still, large mussel colonies did not develop here until the late 1990s, well after it is believed the corrosion began.
The corrosion has pitted steel throughout the harbor, primarily near the water line and tapering off at about 10 feet below the surface. The individual pits are often about the width of a dime and in some places their abundance is weakening the steel, which is used to reinforce the land and make deep-water channels possible.
"The increased rate of corrosion here is believed to have started in the late 1970s, when several significant changes were made to the harbor and surrounding areas.
For one, a new wastewater treatment plant went online in 1978, consolidating the area's industrial and municipal discharges and potentially increasing the harbor's dissolved oxygen while also concentrating the discharge of industrial chemicals.
The Corps of Engineers report also lists the start of filtering for asbestos in the 1970s at Duluth's water treatment facility, a process that added aluminum sulfate to the water and is known to have caused corrosion in the water lines.
Although it was also discovered that some of Duluth's water mains were corroding for other reasons, some have speculated that whatever caused the deterioration of the water lines was transferred to the harbor through the wastewater treatment plant.
"It is probably some combination of factors that are unique to this harbor," said Jim Sharrow, facilities manager for the Duluth Seaway Port Authority.
"I have worked at facilities all across the Great Lakes and I have never seen anything like this," said Chad Scott, an engineer and professional diver who was the first to notice patches of significant corrosion in the harbor in the late 1990s.
"Some companies are experimenting with protective coatings that can be applied to the steel, an expensive proposition considering the work must be done after surrounding water is blocked and then drained away.
Scott said he expects it will take about five years to collect the data needed to fully understand the corrosive effect of the harbor's waters.
Any comments? Any similar, seemingly unexplained cases of accelerated corrosion of steel?
Any clever techniques for cleaning the steel & stopping further corrosion in situ?
The ASM Handbook, Volume 13B, Corrosion: Materials (available December 31, 2005) that I have on order may be already obsolete!?
Ken
Yes, my vote is MIC (microbiological influenced corrosion). The pro-environmental clean-up of the Great Lakes and waterways over the last 10 years in the Midwest has started to promote more biological activity that years past was killed-off from polluted waters. We have seen more fouling and subsequent MIC damage in stainless steel condenser tubing.
I tend to agree with the MIC diagnosis, especially since it seems limited to shallow depths. Less toxics, but still plenty of nutrients, maybe clearer water for more sunlight penetration. But, why haven't the Army Corps of Engineers & other scientists been able to confirm?
Another contribution to MIC may be the invasion of foreign bugs from ships' ballast tanks. See The Milwaukee Journal-Sentinel article
Invasive species fight grows
"The push by Great Lakes states to force the shipping industry to do more to control contaminated ballast spills from overseas freighters grew some teeth this week, when political leaders in Minnesota announced they would join Wisconsin and pursue legislation similar to a new Michigan law....
The twin ports of Duluth, Minn., and Superior, Wis., are the U.S. grain shipping capital of the Great Lakes. That makes it a place where oceangoing ships dump huge amounts of contaminated ballast water, which is pumped from the belly of an otherwise empty vessel in exchange for grain.
The Great Lakes are now home to more than 180 invasive species, and a new one is discovered on average about every 6 1/2 months. Scientists blame ballast water for nearly 70% of the invasions since 1970...
"It’s not rocket science here. It’s sludge at the bottom of ballast tanks."
- Minnesota Attorney General Mike Hatch
Ken
This is kind of going into X-Files territory, but here goes. Near Clam Lake, Wisconsin, less than 80 miles from Duluth, there is a facility used by the Navy for communicating with submarines,while they are submerged.The facility is the antenna for the ELF system, which is extremely low frequency electromagnetic transmission of data. This antenna is miles long, buried in the rock. The site was chosen because of the nature of the rock being ideal for transmitting this type of signal.So, it might be possible for some kind of giant electrical loop to have been created by this system, although given the (presumed) AC nature of the ELF system,there doesn't seem to be a way for this to lead to stray current DC corrosion. The Clam Lake ELF location was a test site when I was at Michigan Tech in the 1970's (it was a big deal in the local papers)and later, perhaps in the early '80's, was expanded into full operation.
Interesting. Perhaps the rock strata & location of the Duluth-Superior harbors at the SW tip of Lake Superior focus the radiation. The extremely low frequency could be considered periodically reversing DC, no? But, there needs to be an explanation for the corrosion being worse nearer the surface. Perhaps, the radiation reflects off the water/air interface?
