Can someone tell me why RAM computes a negative moment capacity for a beam using the composite properties? I checked the documentation and it does use the composite properties if the moment isn't greater than 2x the positive moment.
Unless I'm missing something, the code states that the negative moment capacity should be determined using the non-composite beam unless the slab is reinforced for the neg Mu which I don't think many engineers do.
thanks,
thanks,
