RAM Elements Direct Analysis
staceyb68
thread1342-254809
I am at a new job which has RAM Elements already in use. In the above thread the last comment posted was by FDiego stating, "The Direct Analysis Method will be implemented together with the AISC 360-10 Specification and released in early April 2011."
Has this happened? I have Release 13, and I can't figure out how to reduce the stiffnesses. What is the status on the Direct Analysis Method for RAM Elements? Does RAM Elements have this capability? Not just a second-order analysis with notional loads that considers P-Delta and P-delta effects? And if it does have this capability, does it extend to both LRFD and ASD?
Hello staceyb68,
You will not find the AISC Direct Analysis Method explicitly in v13.0 of RAM Elements. We apologize for delay, but we are in midst of a major consolidation/development effort that will deliver this and a whole lot more (e.g. automatic wind load generation, line supports, etc.) features that RAM Elements users have been requesting.
However, one of my colleagues wrote a nice article on how to handle DAM in RAM Elements that you might want to check out:
If you want to contact me separately, we can see if your project is something we can analyze in our other products to determine if second order is critical.
Thank you!
