oneintheeye
hi, am looking at a design and want to use typical rail loadings. I have a document here which is UK based. Shows 4 250Kn point loads 1.6m apart followed by a udl of 80 kn/m. Now heres the question is the loading per rail? i.e. 2 lines for each track. Or is this axle load if you like across bridge and 80 kn/m is line load acting across whatever the width of the bridge is.
Just to clarify i'm not designing a bridge and no one here knows answer as we are not bridge designers, but i need to determine loading pattern.
