My snow load is 55 psf. The building is 16' x 24' and the rafters are going to run parallel to the 24' length. Is below the correct way to size my rafters (spaced 24" o.c.)?
W= 55 psf (24"/12) = 110 lb/ft
M = wl^2/8 = (110 lb/ft x (12^2))/8 = 1980 lb-ft = 23,760 lb-in.
From Table M4.5-3a ASD Bending Member Capacity I follow the No. 2 Cr M' (Repetitive) column down to Spruce-Pine-Fir and see that a 2x10 has a capacity of 23,700 so I would need to use a 2x12 that has a capacity of 31,800.
Is this the correct way to do it? Are there any other steps?
Thanks.
Thanks.
