Karol2010
- Mar 5, 2010
- 1
Hello
Can anyone help me. I want to use a steped toe raft foundation to build a 2 storey blockwork house on. The outer walls are 2no. 100mm blocks with 100 cavity between. Hollowcore 200mm to first floor. Traditional cut timber roof. I figure the load to be 60KN/m run. The ground bearing capacity at 90Kn/msq. I do not have any software to do a design so if anyone could detail the minimun required steel in the toe that would be great. Also there will be 400mm compacted stone to the underside of the raft throughout.
