radius fillet cutout error
altnickee
61
i am having a error in my attempt to create a fillet
In the attachment a picture of my part.
The textbox explains on witch location I need my fillet of 30mm
Toolmaker
Can you post the actual model for experimenting with?
BTW, you don't need to place the image in a Word file.
[cheers]
Hoping that my part is posted correctly, and can be opened to explore / experiment with.
The fillet needs to be at the end of the ( cut extrude 2 & mirror)
Yes i have tried smaller fillets, op to 5mm radius fillet, no problem, but i want a 30mm radius fillet, because that's the radius of the mill that i have to make the actual cut.
I would like to post the complete part, hoping for a solution.
And how can i post a solidworks screenshot? also for future use.
thanks
Toolmaker
 http://files.engineering.com/getfile.aspx?folder=37996b2d-4dee-4055-9ad2-513ab2fdeb21&file=cilinder_part_for_forum.SLDPRT
Eltron ... faq559-1100 and faq559-1177 are now out of date (obsolete ?). I will try to update them this weekend.
Eng-Tips now has it's own file upload method.
See thread559-199827
[cheers]
Beat me to the punch, Jeff. I did it exactly the same way without any problems, assuming that's the way Toolmaker wants it to be manufactured.
CBL, you need to stop slacking off around here.[wink]
Dan
The R30mm cannot be applied with the fillet tool because it would obliterate the end face of the recess. Except for the Full radius option, all faces involved in a fillet have to remain intact.
[cheers]
Thanks Jeff,
This is a great ” simple” answer to a my question ,especially because my “Solidworks technical English “ needs to learn a lot, so when I go to the SW help section, often the answer is more difficult to understand than the question!!
But thanks to the upload’s we can communicate without a language barrier!
I was wondering if I am the only SW user on this forum that likes to see how other people approach the way of making a part, like we say over here “There are many roads that leads to Rome”
Now we only have to find the Best/ /safest/ fastest method.
Thank again to all the positive reactions from all you guy’s
Toolmaker
I would get rid of the fillet and show the initial 30mm rad in the sketch. The fillet creates a compound surface that does not synch up with the reality of how the part will look when made with a grinding wheel.
Attached is my take on how to go about creating the cut-out. No different then Jeff's other then your first cut.
Cheers,
Anna Wood
SW 2007 SP4.0, WinXP
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
