Rack & pinion-mechanism set up steps
craftmaster
I have a gear that is rotating and the teeth are pushing a sheet metal plate (the pinion).
I have been trying to set this up using mechanism in Wildfire 3.0 without success, I do not have a manual, etc. I want to be able to rotate the gear and see the pinion move in a straight direction. How do I do this? My gear only has 4 teeth, it will rotate about 90 degrees.
thanks for your help
