What are the speeds we are talking here?
Are there any restriction on using other car model? This one will need quite a bit of tinkering!
1. Re-profile curves over the tyres, if tyres cannot be narrower. Front tyre curve seems notorious to me -drag wise!
2. Strip out the rain-stopper strip above the windows. If you are racing, you dont need them!
3. Two front holes, if they are head lights, bring them in forward - in line with the other surfaces. Else fill them or make them thru to tyres, if you have information that ventilation is beneficial at that location.
4. Reduce/remove the hump over the hood or atleast give a cure, instead of current filleted corners.
5. Seal all gaps between surfaces, for example front guard and car body!
6. If its for racing, remove the aft door handles, cover them.
7. Bring the window glass in line with door surface. Or atleast cover the aft window with sheet metal. And remove the protruding black circle.
8. Move up the spoiler, currently its in the wake of car, not sure how effective it actually is.
9. Cover the exposed machinery on either side, below the door.
10......and lots more
What are the considerations? Time/Cost/Car Model?
Tejas
