Yes I have all the formulas and no this isn't a school project but this is critical enough that I'd like some expert opinions please.
I'm building a "Racesaver" 305cuin small block Chevy. This is a sprint car series 'spec' motor and I will be documenting it in Engine Builder magazine - hence asking the right folks!
Rules call for solid lifter cam. Keeping the lifters oiled at 7000 rpm is sometimes a problem. Old NASCAR engines put a tray under the cam that filled with oil, splash lube.
I'm looking to drill and tap the oil passages above each cam lobe. I can get orifice nozzles that will thread in.
Since there are 16 of these little buggers and another that lubes the timing chain, I need to be pretty accurate on sizing. Sketch attached.
The oil will be a 5w30 synthetic,(11cSt @100C) engine temp about 200F, the wet sump oil pump puts out about 70 psi at 7000 rpm.
I can get thread in misting nozzles as small as 0.2mm (0.008")diameter for about $20. The 0.003" lab grade ones would add almost $300 to the build. So I need to balance that. I think my rough calcs showed the 0.008 would flow around 2gpm total which could starve the bearings.
This whole thing might not be worth the effort but it's one of the article items. If this deal makes it to press, I can come back and add the link
THANKS FOLKS!!
THANKS FOLKS!!
