hello I have been studying Air conditioning and refrigeration technology 5th edition (A book from USA)I have no experience in air con and refrigeration I am Novice in this field so to speak.In responce to the above question its very important as to who did the retrofitting bcause to start with a higher saturation presuure and temp. means higher compression ratios or in other words extra load on the compressor like some one suggested to check the subcooling and super heat values and further these can be matched with the design P/T of the unit and difference worked out or an amp draw test on the comppressor would yield any abnormalities from the FLA and LRA on the compressor further if its a TXV than it definatly needs adjusting considering the high subcooling value stated in the question there was no mention if the system was deep evacuated, leak checked,and charged properly or fractionation and temp glide are occuring due to old refrigerant still present in the system so any non codenseables, in the system can relate to the above symptoms. I am working as an electricians mate and have a years experience in domestic installations I am interested in doing an HVAC course and someone has suggested that i do F gas 2079 to get my first step in the industry.What I have learned from the book has given me a tremendous insight into the hvac industry and I have a good understanding of the basic techniques such as how and when to charge a unit,how to charge a unit,i.e. vapour and liquid charging,system evcuation,leak checks under standing pressure test,calculating superheat and subcooling,fault diagnostics etc etc. my question is I am financially weak and can jut afford to do the F gas 2079 can someone give me an honest opinion as to whwt would be the best course of action to get a job in the HVAC industry before i enrol for the course as I am 49 years old and due to a late marriage i have a 3 year and a one year old child to support so im in no position of taking chances and would only spend money on a course if it brings any fruit. apart from electrical wiring work i also have experience as a helper to install residential split units so I am familiar with pipe work,hanging indoor units on the walls, fitting wall mounting brackets for out door units, insulation of the liquid and suction lines and fitting ducts for pipework them,cleaning condensor and evaporator coils, return air filters,etc. So please give me an honest opinion thanks in advance.
