pedromorgan
- Jul 23, 2006
- 14
Is it possible to measure the length of a curved line on autocad 14?
If there are several curves can I join them together and measure the length of the whole line rather than measuring each of the curves in turn?
I have a drawing of a door that I want to import as a block into another drawing of a house where it will be used several times. Is it possible to do it so that if I make a change to the first drawing it will show up on all the blocks in the second?
Thanks in advance
Peter Morgan
Thanks in advance
Peter Morgan
