May 6, 2006 #1 EricM9 Structural Joined May 4, 2006 Messages 6 Location US What value of R-factor do you use if your designing a balcony? Do you guys still consider seismic loads for balconies? The plan dimension is 24ft x 10ft. Thanks!
May 6, 2006 Thread starter #2 EricM9 Structural Joined May 4, 2006 Messages 6 Location US I believe the correct term is "deck" right? Balcony means there is no external support. So it is a deck. Hope to hear from you guys very soon. Thanks! Upvote 0 Downvote
May 7, 2006 #3 JAE Structural Joined Jun 27, 2000 Messages 15,712 Location US Correct me if I'm wrong, but the R value to use for portions of the building (such as a deck) should be the same as that for the overall building. Upvote 0 Downvote
May 7, 2006 #4 haynewp Structural Joined Dec 13, 2000 Messages 2,330 Location US I think I would look at a different R only if the lateral system was independent of the main building. Probably is connected and use the same R. Upvote 0 Downvote
May 8, 2006 #5 archeng59 Structural Joined Aug 24, 2005 Messages 621 Location US R = 3, unless you are doing special seismic detailing per AISC. Upvote 0 Downvote
May 8, 2006 #6 skier1578 Structural Joined Jan 6, 2005 Messages 43 Location US If you have cantilevered columns of some sort supporting your deck, then R=2.2 (per the UBC & CBC table 16-N). Upvote 0 Downvote
