R/1000
aeronavale
GB
hello!
I was presented a graph of R/1000 over TIS. Can you tell me please how is this graph constructed and what it means?
I need to know the exact data and how you calculate it, in order to understand its meaning.
Thanks!
We need to know what the hell you are talking about in order to understand your question.
Mike Halloran
Pembroke Pines, FL, USA
I thought you know if you're in automotive, repairs per thousand and time in service, only people who know can answer me I bet
Yes, I already said that, but any help?
What do you mean? It should basically resemble the classical bathtub curve for reliability, i.e., high at start of service and end of service, and relatively constant in the middle.
R/1000 is essentially a failure rate.
TTFN
faq731-376 forum1529
This is a generalized reliability engineering question, not a uniquely automotive engineering question. The give-away is that Google doesn't return meaningful results, so it means this is not a phrase that is typically used. Adding the word "reliability" returns meaningful results.
Here's a list of sources, mostly available from Assist Quick Search.
MIL-HDBK-108 NOT 1 Canceled QUALITY CONTROL AND RELIABILITY - SAMPLING PROCEDURES AND TABLES FOR LIFE AND RELIABILITY TESTING (BASED ON EXPONENTIAL DISTRIBUTION) (NO S/S DOCUMENT)
MIL-HDBK-109 NOT 1 Active Quality Control and RELIABILITY - Statistical Procedures for Determining Validity of Suppliers Attributes Inspection of
MIL-HDBK-189C Active RELIABILITY Growth Management
MIL-HDBK-217F(2) Active RELIABILITY Prediction of Electronic Equipment
MIL-HDBK-251 Active RELIABILITY/DESIGN THERMAL APPLICATIONS
MIL-HDBK-266 Canceled APPLICATION OF RELIABILITY - CENTERED MAINTENANCE TO NAVAL AIRCRAFT, WEAPON SYSTEMS AND SUPPORT EQUIPMENT (S/S BY MIL-STD-2173)
MIL-HDBK-338B NOT 2 Active Electronic RELIABILITY Design Handbook
MIL-STD-683 Test Methods and Procedures for Microelectronics
MIL-STD-756 Reliability Modeling and Prediction
MIL-HDBK-781A Active RELIABILITY TEST METHODS, PLANS, AND ENVIRONMENTS FOR ENGINEERING DEVELOPMENT, QUALIFICATION, AND PRODUCTION
MIL-HDBK-1823A Active Nondestructive Evaluation System RELIABILITY Assessment
MIL-HDBK-2067 NOT 1 Active AIRCREW AUTOMATED ESCAPE SYSTEMS RELIABILITY AND MAINTAINABILITY (R/M) PROGRAM REQUIREMENTS FOR
MIL-HDBK-2173 NOT 1 Canceled RELIABILITY-CENTERED MAINTENANCE REQUIREMENTS FOR NAVAL AIRCRAFT, WEAPONS SYSTEMS AND SUPPORT EQUIPMENT (REFER TO NAVAL AVIATION RCM PROCESS, GUIDE MANUAL, NAVAIR 00-25-403)
ARMP-1 ED.4 Active NATO REQUIREMENTS FOR RELIABILITY AND MAINTAINABILITY
ARMP-5 Canceled GUIDANCE ON RELIABILITY AND MAINTAINABILITY TRAINING
ARMP-8 ED.1 Canceled RELIABILITY AND MAINTAINABILITY IN THE PROCUREMENT OF OFF-THE-SHELF EQUIPMENT
ITOP-2.2.509.1(1) Active Tracked-Vehicle RELIABILITY, Availability, and Maintainability
ITOP-5.1.014 Active Statistical Methods of RELIABILITY Determination
ITOP-5.2.623 Active GENERAL REQUIREMENTS FOR ESTABLISHING RELIABILITY OF AIRBORNE FLIGHT TERMINATION SYSTEM COMPONENTS
NAVAIR 00-65-502_NAVORD OD 41146 Reliability Engineering Handbook
NOTS TP 3716 EX POST FACTO RELIABILITY CONSIDERATIONS
QAP-259 ED.1 Active RELIABILITY/CREDIBILITY CRITERIA
RELIABILITY: A Practitioners Guide
