QW 407.1 & .2 PWHT of 304 Stainless 1
jrupert24
We want to do a low level stress relief for stainless steel. Our current WPS shows a range of 1650-2000F PWHT. The pqr used the 1650F. The way I read it, we can determine that range for this P number. Can I just revise the WPS with a new range? It appears that it is not that important for P8 materials. Can someone help?
jrupert24;
Do not perform a low temperature stress relief for P-No 8 material (304). It will not serve any useful purpose. Your PWHT for 304 weldments in your WPS is actually a solution anneal post weld heat treatment to remove the effects of sensitization from welding. The 1650 deg F for your PWHT needs to be much higher in temperature, more like a range of 1900-1950 deg F, followed by rapid cooling to avoid the temperature range of 850-1400 deg F.
Any low temperature thermal treatment is a waste of time and money. Plus, you can undo the solution anneal heat treatment that was required in your WPS.
We were just looking for options to stay outside the sensitization range, but I agree with you that it probably won't do much. I think in the end we will go with the 1950 solution anneal. The issue is that it is a very thick weldment (5.5" thick) with branch connections, etc. and we are wondering how we will cool it fast enough.
Do you happen to know what kind of a cooling rate I would need in degrees per hour through that range?
jrupert24;
I am going to ask a stupid question, why are you even considering any form of thermal treatment after welding 5.5" thick material. You would need one heck of a furnace and quench tank.
Why are you having any thermal treatment after welding such thick section components. Do you need a re-solution heat treatment? Can you get by with controlled welding and live with some sensitization?
