Thanks Keith and Dan! Great advice!
Keith. Yeah, I've ran across those light engine configurations in the Digi-key catalog and wondered what they were. The one inconvinience about them is that they are already in clusters. I'm thinking about putting 100+ total Red, Green, and Blue LEDs on this panel depending on the brightness of the LEDs. And I'm predicting that since they are already in clusters, that might limit the quality of light distribution. I would like to put LEDs in rows on my panel so that the LEDs are close together.
Dan. As for cooling, since the ROV will be under water, the LED array will ba sealed by encasing it in in clear resin used especially for SONAR transducers and prevent water bubbles from forming within the resin. The lack of air bubbles in the resin will prevent light scattering in the resin.
Aside from that, the water could be used for cooling. I might mount some corrosive resistant aluminum heat sinks to the back of the array so that the heat generated by the high brightness LEDs is dispered immediately.
Thanks again for your help!
