NX version 7.5: I am editing an existing drawing I did not make myself, but I am trying to edit a view boundary for an existing view. The boundary has been set by a set of curves (lines and arcs) that are dependent on the view itself and move with the view. I understand you can create a sketch that is dependent on the view, but I have been unable to find how to insert a curve that is dependent on the view, that I can use to adjust the view boundary with. Using Information>object gives me what is shown on the attachment. You'll notice the CURVE is dependent on the view, however I can only insert curves on the SHEET and not a view.
Thank you in advance for your help.
