Hello All!!
I am currently working on a slow moving (15mph max) off highway vehicle that has a tandem pump directly coupled to the engine. There are two operator control levers connected to the pump via mechanical linkage.
I am trying to eliminate vibration transmitted from the pump/engine to the control levers. One option I am considering is some sort of "drive by wire" configuration (possibly microcontrolled servo or stepper motor?). Can anyone tell me if this can be done economically and possibly list some resources? Everything I have found seems to be for expensive industrial motion control systems.
Some of the initial design parameters:
+/- 21 degrees of rotation (42 degrees total travel) to control each pump input shaft
Actuate the full range (42 degrees) within 1 second
requiring around 10-15 ft-lbf
12 V DC electrical system
Harsh conditions including engine vibration and some moisture
What do you guys think? Is a servo/stepper motor system a good option for this application, or am I missing something. Any info or ideas will be greatly appreciated.
