Does anybody know if this is an actual process for coating steel (double-hot dip galvanizing)? I am trying to find a slightly more economical solution to stainless, and stumbled across this in my research...
Double galv isn't dipped twice, it has twice the coating weight. As Ken said, selection of alloy, surface roughness, temperature, speed, and galv alloy all factor into coating weight.
What king of parts are you working with? There may be more economical stainless options.
Rust never sleeps
Neither should your protection
Thank you Gentlemen. In my continued research I did eventually find mention of coating weight, which is probably what was meant by that statement. It definitely makes sense anyhow
These parts would primarily be deck hardware and bracketry for a boat yard/launching facility (i.e. forklift stop plates, travel lift wheel guards, pivot plates, etc.). They be boled to a concrete deck, and be in direct and frequent contact/exposure to salt water, sunlight, abrasion, etc. Obviously S.S. 316 would be a great solution for this situation, however, when required plate thicknesses are approx. 0.5-1" (and areas greater than 200sf), it's not something most Clients can afford.
I am thinking that a structural A36 with a "heavy-weight" HDG coating would be the most cost effective solution, while providing similar (if not better) service peformance than it's economic [stainless] equal... I mean, I would get better strength allowing me to reduce the thickness, thus creating a cost savings for the extra surface prep. and heavy-HDG.
