MadameAM
- Dec 6, 2010
- 5
I am looking for the french term for "control hunting", as describe here:
As condensate backs up in the exchanger, the heat transfer rate to the process is greatly reduced. The control valve opens wide enough to allow flow into the exchanger. As condensate drains out, the steam space is now greater and the steam pressure increases. The process overheats, the control valve closes down, and the cycle repeats.
I tried to use all the translation resources I know of, but could not come up with anything. Does anyone knows?
