I have a part showing BAISC dimension, with profile, flatness and parallelism control.
The default tolerance in this drawing is +/-.005"
see attached. If required showing the measurement (diameters and height) in the First Article Inspection Report, what is consider out-of-spec,
Diameter: 3.798"
Diameter: 5.004"
Height: .630"
Diameter: 3.798"
Diameter: 5.004"
Height: .630"
