ERIMechEng
- Sep 22, 2009
- 20
Problem: Need to drop load-bearing shaft into a mechanism, and couple the load bearing shaft to a shaft with a brake (please see linked PDF). Zero torque, zero speed until shafts are coupled. Shafts are both approx. 1.5" dia. Transmitted torque = 600 in-lbs @ 100 rpm.
I need help with the coupling mechanism. Must be manually operated - no elec, hyd, or pneumatics available. Also, need something maintenance free (or very low maintenance). I would prefer something off-the-shelf.
I have found something that will probably do the job:
but I was looking for any alternatives. Any ideas?
/R - Matt
/R - Matt
