Questions about Feature Control Frame Menu - NX9
randy64
Aerospace
1) Is there a way to insert the Between Symbol, e.g. A<---->B below a FCF, other than drawing it in?
2) When I try to use the FCF Function, I only have an option for primary reference datum (see attached). How do I get the option for secondary and tertiary datums?
 http://files.engineering.com/getfile.aspx?folder=2d9d065c-f6ec-41ea-b5a2-4eea5d27396b&file=FCF.pdf
Okay, found the Between Symbol, but still need an answer about the Secondary and Tertiary Reference Datums.
I am facing same issue. Please share your solution if you have found one.
Thanks in advance.
