rockman7892
I'm looking at the attached drawing for a 750V DC MG set for rollers in an aluminum mill and was hoping that some of our gen/motor experts here could help shed some light on a few items for me. These gen and motor units have separate exciter control enclosures and the main 750VDC distribution is fed from generators to motors through a 750V Switchboard lineup which contains breakers and switches shown on one-lines.
1) For both the DC generators and motors there are both separately excited field windings as well as armature windings. From my little experience I'm used to seeing one or the other but not both....either a separately excited field winding or a shunt/series winding but not both. Is there an operational advantage to having both?
2) What are the C&C windings on both gen and motors (purple cloud)? Are these typically located on the units itself or the control/distribution board?
3) What are the resistors and OV relay on the generators for (green cloud)? These appear to be for some sort of overvoltage relaying/detection?
4) the DB resistor in the on the motors (blue cloud) appear to be used for dynamic braking, to slow the motor and prevent it from producing back EMF?
5) What are the resistors (red cloud) used for on the motor circuit. I'm assuming these are used for speed control of the motor with the (3) different contactors being used as means to change resistor value for speed control? What about the resistors on the generators (red cloud) Are these resistors typically on the unit itself or on the control distribution board?
