Golden506
Student
- Jun 1, 2023
- 1
I'm considering going to school to study engineering. I've done quantitative research on things like salary, job outlook, educational requirements, etc. However, I still have questions of a more qualitative nature that I would like to ask of actual engineers:
[ul]
[li]Beyond having good math skills, what kind of person makes a good engineer? And what are some attributes of someone who is not suited for the profession?[/li]
[li]If you go into an engineering specialty, are you locked into that field or is it reasonably easy to switch fields? For example, I'm considering biomedical engineering as a field of study. If I turn out to hate it, would I be able to find work elsewhere?[/li]
[li]If I study something general like ME, will I still be competitive for specialized jobs in, for example, biomedical or aerospace engineering?[/li]
[li]What does work-life balance look like for most engineers in the U.S.? Are long hours frequently required? Does work tend to follow you home?[/li]
[li]How much control do you have over your work? Are you frequently making executive decisions and seeing projects through from start to finish?[/li]
[li]How can I find more engineers to talk to, or otherwise gain more insight into engineering as a field?[/li]
[/ul]
[ul]
[/ul]
