Hi gang, I'm working in wildfire 2. I have a problem. In 2001 it was possible to create a quilt (create, surface, copy, select solid part) and then a quilt is created over the completed solid. The goals are this, create a quilt over solid, then mirror quilt, then create a solid from the quilt. I have tried the edit, feature operations, and mirror the ENTIRE part, datums, copied external reference, etc. but when update or regeneration are done it what to fail on the mirror geometry. Can someone help me out.
Texaspete
Texaspete
