Quick and hopefully simple question.
i attached a portion of the blue print of a part i'm looking over. The question i have relates to the true position of the 4 diameter holes which is based on a composite feature control frame.
Basically i'm trying to determine if the holes are good in one sense to the part and then to each other.
So my questions / or verifications are:
The .017 true position will utilize the .677BSC dimension as this the primary datum it ties to and then i calculate if the other holes meet the specifications within the .017 & Maximum Material Condition modifier?
But what i'm more concerned about relates to the .005 portion of the true position call out. It has a basic of 1.05 from Datum D / E. But what if the hole location for the .017 true position is on the high end of the tolerance.
For example...say the hole location measured 1.090 from Datum D. The first true position call out of .017 will accept this value. But the true position call out of .005 will not since .004 is already well above this tolerance.
i just want to verify, is the .005 call out based on where the holes are located in reference to the first true position (.017) and then the holes to each other need to be .005 or is the 1.05BSC also dictating where the 4 holes start from each other?
So in other words, first hole called out 1.050BSC can be further than this so long as it is with the .017 tolerance and then from there the holes will need to be within the .005 true position and thus i'm not necessarily using the 1.050BSC dimension to determine the second half of the composite control frame.
