Hi Everyone,
I have a question regarding how flatness should be check on multiple datum planes.
Side Section View
Top View
Would I check flatness of these areas locally excluding each other datum?
Or are they checked together. For example would I put the part on the checking fixture unclamped and slide a feeler under each Datum net pad area?
Or are the areas in between and around each datum considered in the flatness call out?
Thank you,
Side Section View
Top View
Thank you,
