The bushings i refer to are for A-arms with a shaft through the bushings and in the A. This shaft mounts the A-arms to the chassis.
Basically a good design, but to properly press the bushing out and in, the shaft is always in the way. A lot of arms get bent.
I'm investigating this, because i'm going to change from rubber to solids. With the original rubber bushings, most just burn out the rubber to avoid bending the arms. With solids of course this is impossible.
