ziggle314
- Jan 8, 2014
- 2
Hi folks,
I am an electrical engineer who is doing some reading on structural engineering -- purely recreational. I am analyzing the following situation.
I found an article in the Journal of Lightweight Construction that presented the following formula for the tension in the rafter tie and I decided to derive this equation myself using the method of sections on half the roof.
I mentioned this equation in a blog post on my recreational efforts and I received the following comment.
I find this comment confusing. Is the tensile force in the rafter tie really twice the force it exerts on the ends? If I had a weight hanging from a rope mounted to a ceiling, it seems like the rope is pulling on the ceiling and the weight with equal and opposite forces, yet would be under a tension equal to the weight of the load.
One thing I note from your analysis is that the thrust T is fine for calculating the load upon the tie to rafter connection, but since this analysis considers only half the roof, the same effect on the other half of the roof would therefore create a tensile force in the tie member of 2 x T.
