Question on equalizing datums for you, with reference to the attached sketch (I've embedded the image too - it's only 95k so hopefully won't kill anyone's download time etc.) and ASME Y14.5M-1994 (I don't have 2009 and we still work to -1994).
As shown in the bottom left view, I want the major & minor axis to be used to generate datums B & C - essentially getting center planes from the length & width. The ellipse shape is the interface at the assembly level as it fits in an ellipse cut out.
If it was a machined part I'd do it as bottom left view labelled 'conventional datum structure'.
However, the part is to be cast and the foundry we work with usually prefers datum targets which is typical for castings. However, due to the shape of the part and it's functional interface I think Equalizing Datums using V type equalizers make sense rather than simple datum targets.
Q. I was hoping someone with some experience in these matters might be able to tell me if I've got it right in View A-A. Is it OK to use the V-type equalizers on both ends? Figure 4-38 only has them at one end with conventional targets at the other - though of course "The absence of a figure illustrating the desired application is neither reason to assume inapplicability, nor basis for drawing rejection".
Also before any one brings up my labeling of the center lines as datums in this case I believe it's acceptable per the last sentences of 4.6.6:
Thanks,Ken.
ASME Y14.5M-1994 section 4.6.6 Equalizing Datums said:It is permissible, in such a case, to use the datum feature symbol to identify the equalized theoretical planes of the datum reference frame. It should be noted however, that its is an exception, and is to be done only when necessary and in conjunction with datum targets.
Thanks,Ken.
