ZippyDDoodah
- Jun 7, 2009
- 38
Our company is starting to do more piping design and analysis, and as a structural engineer who will be involved with this work, I want to be sure that I understand what's going on as much as possible. In this context, I have a couple of questions for you pipe stress engineering 'veterans':
1) How is the flexibility factor k from Appendix D supposed to be applied for elbows? Is it treated as a reduction factor to the moments of inertia (EI) of the elbow pipe/frame section or what?
2) I can't get a definitive answer from our piping engineer or from the software documentation as to what our pipe stress analysis software is doing internally with regards to modeling elbows. We have a 2 year old version of AutoPipe and also a prepaid run version of Caesar II. Would anyone happen to know if these programs analytically treat elbows as curved elements, multiple segments of straight pipe section to create the curve, or whether they treat it as just two pipe frame sections intersecting? Because the answer to that question would make a difference.
I understand that both programs automatically determine flexibility factors and SIFs, but results would be different, depending on whether the pipe/frame elements are true curved elements and also depends heavily on how well the pipe elements account for torsion.
3) Turning on the water in my garden hose tells me that Bourdon effects might be a consideration, yet the B31.1 code does not address this effect from what I can find. Our piping stress software gives vague references to their Bourdon calculations which are offered as an option, not a default. From your experience, are Bourdon effects "typically" important in carbon steel piping? If yes, how do you account for them?
4) Last couple of questions which don't have anything to do with the title of this post - If there is a SIF required for concentric reducers in B31.1, why not a SIF for eccentric reducers? This makes no sense to me. Also, since reducers are non-pipe components, aren't they typically fabricated with thicknesses which would make them stronger than the connecting pipe? If so, why would B31.1 require a SIF for reducer components?
Thanks in advance for any advice that you all might offer.
