Is it allowed to use the ASTM A312 Edition 2019 and ASME SA 312 Edition 2019 for seamless pipes Grade TP316/316L
A manufacturer stated in the material certificate for the technical standard ASTM A312/A312M-19 Edition 2019 and ASME SA 312 : Edition 2019.
According to ASME SA-312/SA-312M it is identical with ASTM A312/A312M-15 . The manufacturer used in the certificate a newer Edition of the ASTM A312/A312M-19. So is it allowed to write in a material test certificate a newer ASTM-Edition instead of the ASTM Edition mentioned in the ASME Section II Part A. Edition 2019.
Thanks a lot for your replies.
