question about rack and pinion
aroundhere
Petroleum
Sep 21, 2006
175
I finally created a rack and pinion in a sub assy, but it does not work in the top assy. I set the sub assy to flexible. Does anyone know if this should work, or must the rack and pinion be created in the top assy only?
thanks
The mates used in the top level assy are probably restricting the sub-assy's flexibility.
In big models, nesting flexible sub assemblies will often result in flexible subs that don't solve well and don't drag. Do you get a "The selected component is fixed. It cannot be moved" tooltip or does it just not move?
