Our cust specify that our pumps need to start under an 80% voltage condition so we size our motors acordingly. We manufacture Cryogenic pumps for the LNG market so we are talking submersible applications. We are starting to question the start torque curves provided to us by the manufacture. Example We started a 1100 Kw @ 6600V 12 Stage pump with a 36% volatage drop in less than 2 seconds. So according to calculations we started this large pump @40% available torque in under two seconds. According to the Motor manufacturer the
The temp effects on the motor reduce the available start torque by at least 30% at 0 speed they give us a modified torque curve based on this idea. So if there calculations are correct shouldn't we see an increase in start time with the voltage drop of that magnitude.
