Question about FAG "H76" suffix 2
udroiul
DE
Does anybody know what means H76 suffis on spherical roller bearings from FAG?
Thanks,
H usually refers to an adapter sleeve, but H76 doesn't match anything.
My guess is a date code or batch number or something else which is insignificant
H7 is a bearing housing clearance specification. Maybe it means the clearance is between H6 and H7 but you will have to check with FAG.
H76 means the bearing has a spiral groove on the bore. This is usually used in rolling mill applications to inject grease between the shaft and inner race to allow for easier removal.
