I don’t know where to start…
I was not trying to create universal rules for tolerancing all kinds of cones in all the situations.
I was trying to address using runout when tolerancing cones.
I noticed that note in 8.1 says “orientation alone of the leader line does not influence the definition of the tolerance zone”. Nevertheless in illustrations to para. 18.15-18.16 leader is always shown normal to the geometry, except “tolerance in a specified direction” case where it was clearly controlled by dimension.
So, I assumed (maybe wrongfully) that it was the case that confused OP otherwise familiar with the concept of runout.
Then, I tried to address the question about alternative to combining circular runout with straightness.
Once again, I assumed that if OP was asking about runout, then some other form of runout would be the right choice.
In ASME the total runout could do the job, but the situation in ISO was not that easy.
ASME Y14.5-2009 Para. 9.4.2.1 says:
“Where applied to surfaces, constructed around a datum axis, total runout may be used to control cumulative variations such as circularity, straightness, coaxiality,
angularity, taper, and profile of a surface.”
So ASME explicitly permits (and encourages) use of total runout on conical surfaces.
ISO 1101:2005 when making distinction between circular and total runout also seems to distinguish between features they can be applied to.
Circular runout is divided into:
Circular run-out tolerance —radial (measured perpendicular to the axis)
Circular run-out tolerance —axial (measured parallel to the axis)
Circular run-out tolerance in any direction (measured normal to geometry, straight or curved)
Circular run-out tolerance in a specified direction (measured on specified angle to the axis)
While total runout is limited to:
Total radial run-out tolerance (the tolerance zone is limited by two coaxial cylinders)
Total axial run-out tolerance (the tolerance zone is limited by two parallel planes)
And that’s it!
The opinions on the matter even between people highly versed in ISO standards differ:
G. Henzold sees no problem using total runout to control conical surfaces, but he sometimes mixes ASME and ISO applications.
Henric S. Nielsen is pretty clear that total runout can only be radial or axial, and radial TR only applies to cylindrical features.
The question of how far one may extend the principles still open.
By the way, anything new about total runout in 2012 version?
