NewEngineer
Hi everyone. I am a new engineer, and I am having some trouble doing a hand calculation. (My mentor at work gave me this assignment and said a simple hand calc would suffice)
The problem I am working on is that we have a Bar Grating installed spanning two ledges, almost making a bridge. It is about 4ft long (also the way the bars run) by 2ft wide. However, there is a spot that is 9 inches wide, and 8 inches deep, where there is a cut out. I figured out that 5 of the bars will not be able to span to both ledges, making 5 cantilevered beams.
I am supposed to figure out a way to make it take a certain load, around 250-300lbs per square foot. I can do this however I want, but he said probably either by welding a bar to the ends of the 5. Or by welding an angle somewhere.
As a new engineer I really need some guidance. I am not sure how to go about assuming things and being able to do a hand calculation. Ive been trying to do some beam analysis, but am not sure how to do it for more than one bar in a row. Any help or tips would be great
