Query on Abaqus *fil file
Tinni1
IE
I have a query regarding importing imperfection from linear buckling analysis.
I have provided command in the edit keyword section as below:
Node File,
U
As I understand that if I conduct a linear buckling analysis, then a *fil file will be generated which contains the coordinates of the normalized eigen modes obtained from the linear buckling analysis.
In my case, a FIL file is generated in a text pad format. But when I am opening the file it is not showing any coordinate instead shows some unknown characters that I am unable to understand.
I am attaching the FIL file here.
Could anyone provide any direction, why I am not able to see the coordinates in the *fil file?
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1641498689/tips/Job-1_rfieil.fil[/url]?
That's a legacy format with binary output, it's meant primarily for use in external postprocessors. If you want to read the values, you should use another output format - dat file:
*Node Print
U
It is possible to switch the file format from binary to ASCII with this command:
*File Format, ASCII
Thanks for your response.
@ Mustaine3
Could you please let me know, where should I write the command in the edit keyword section?
Is that like below?
*Node File,
U
*File Format, ASCII
Thanks in advance.
Yes, you can do it this way. Just remove the unnecessary comma:
*Node File
U
*File Format, ASCII
It's ok that way.
Quote from the documentation:
"The *FILE FORMAT option can be given as model data or as history data, but it can appear only once in the input file."
Great! many thanks!
What would be the procedure for EXPLICIT? I keep reading the manual with no success. The only info I've been able to find is to write convert=select but I lunch my analysis in a cluster and I don't have that option.
In Abaqus/Explicit you have to use the .sel (selected results) file instead of .fil or .dat files. After the analysis, the .sel file can be converted to .fil using this command:
abaqus convert=select
that is from command line only, correct? Any option available to transform the sel into fil within the *.inp file?
Yes, it’s like the command that you use to submit the job (e.g. abaqus job=…). It can’t be done from the input file but it shouldn’t be a problem to submit such a command even when running the job remotely.
I found how I can add that to the cluster bu that's what I receive:
job=XYZ.inp convert=select cpus=32 memory=30720MB interactive
b'Abaqus Error: Command line option "scratch" may not be used with "convert".'
According with the manual the two commnad (scratch and convert) are not mutually exclusive. Also I'm not using scratch so I really don't know what should I change
Try without the additional parameters, just this:
abaqus job=job_name convert=select
Unfortunately I cant, I use a cluster so some paramters are there by default, I can only select how many cpus to use, but cant' get rid of the cpu command. It's nervewrecking because I have a .sel file I just can't read it
What about the other parameters - can't you remove them ? Another option would be to copy the file and convert it locally if you have a license for that.
I'm trying to convert the sel into ASCII on my computer. Difficult as well since I can't install any .exe
