Quench water vs RO
msii
AU
Hi All,
Our pump supplier has mentioned that water entering the mechanical seal needs to be quench water. On our site we do have a RO system and want to make sure that Quench water is the same as RO water. Are they same or different?
thanks in advance,
best regards,
RO water will work fine for quench water. The pH should not be below 6 units. See the link.
[link file:///C:/Users/Trent%20is%20Based%20God/Downloads/EagleBurgmann_63E_E2_PDF_E3_Barrier-buffer%20media%20for%20mechanical%20seals_02.14.pdf]Link[/url]
Confirm with the seal supplier.
