P
pubojeff
Guest
I want to use skeleton design method to design a worm gear pair.
My question is on the skeleton building this section. When I drawed out the orthogonal sketches, then I
built the motion assembly. As usual, on this active motion assembly, the ground part and the first gear I
successfully create them. The gear 2 failed to build up its part.
I practiced and some skeleton design cases only plane structure, not 3D mechanical structure.
I had been building up the plane gear pair BUT this time in vain. How to do it?
