I'm working on an application where I need to intercept an existing PWM signal (~120Hz, 0-12.0V) - which is limited to 20A max current - and output an identical signal with a capacity of up to 60A. The signal controls a single brushless DC motor but my application will add another (identical) motor in parallel with the first (and possibly 2 more motors).
Based on my limited understanding (never worked with any kind of transistors) and what I've been able to gather researching online, I thought N-channel MOSFET's might be just the thing and I've come up with the attached circuit that I believe will meet my needs.
I'm considering using a pair of IXYS HiPerFET IXFE48N50Q in parallel to give plenty of overhead. Am I on the right track with the circuit design? If so, are the IXYS units a good fit (if a little expensive)?
Link to IXYS specs:
Appreciate any insight/feedback.
Mikah B.
Link to IXYS specs:
Mikah B.
