PWHT 1
3lilaggies
52
Is there an actual ASME code limiting the number of times I can PWHT WC6 P4 material? Any help on this subject would be greatly appreciated.
Possibly - how is that for an ASME response?
If the application of the casting requires impact testing per a specific Code or Standard, cumulative PWHT time becomes an essential variable because this will affect impact properties.
If impact requirements are not specified, you can repair a casting as many times as necessary OR unless the purchaser has specified in the PO a limit as to the number of weld repairs.
Thanks metengr, there is not any impact testing for this part. Thanks again
