OK that's what I get for getting in a hurry... sorry for the incomplete initial post.
The crack is in the weld metal, not the base metal so it is not in the HAZ.
The pipe is not solution-annealed as far as I know.
This spool piece is one of 28 gas distribution laterals of different length that are installed in the bottom of a vertical sparge vessel (a reactor). The lateral has (17) 3/4" diameter holes, about 2" o.c., on the bottom CL all along its length.
A gas flows through the lateral and out the holes where it bubbles up through a liquid iron chelate solution. The laterals are submerged in the solution. There is about 3' of solution level above the laterals. The gas is 60% CO2, 25-30% CH4, water-saturated, with 15,000 ppm H2S. THe process removes H2S from the inlet gas stream by converting it to solid elemental sulfur. The process conditions are T = 110° F and 6 psig. This is the normal service condition.
Twice a week, each lateral is cleaned in-situ in service of solid sulfur by passing utility gas (methane) at 200 psig through it for about 10 seconds. This is required because the solid sulfur that precicptates out during the reaction is sticky and collects on the laterals, causing backpressure and reducing the effectiveness of the process. This 'gas blast' knocks off the solid sulfur that collects on the lateral holes. This blast does cause a cyclic load on the lateral but I do not think the magnitude is high enough to cause the cracking in and of itself, although I have not calc'd its magnitude and I do need to do that. Assuming the stress magnitude is low enough, would not an annealed condition in the weld increase the ductility enough to prevent cracking? Thanks - Pete
Thanks!
Pete
