PVC Polyblend?
  • Thread starter Thread starter -
  • Start date Start date
Guest
CD's are placed on a PVC Polyblend pad and are then printed with UV curable inks. These inks tend to stain the plastic pad and I have not found a reliable way to clean the surface without ruining it. Does anyone have a suggestion on what type of material to use? The pad has been designed to resist chemicals so that is an option. But what should be used with the chemical?
